Old 13-Dec-2012, 6:18 PM   #1
evilrt
new here, new to ota, new install (pix). am i missing anything?
let me just say that this place is great. i lurked here for about a month learning some things and decided to get an ota antenna for myself.
let me also say that i am not a cord cutter. i really enjoy my FiOS service and would go insane without pay channels. i did the install as a backup for when trees fall during storms and knock out the Verizon services. this has happened 4 times in the 5 years i've lived here.
as you can see i live fairly close to the major network transmitters which are all clustered together so that was a bonus. that is what made me decide on the Channel Master 2016 with 75' of Belden 1694A coax. its mounted on a 25 foot mast and is sitting 27 feet above ground pointing at the Empire State Building.
i had 2 existing ground rods 8' apart from each other so i added an additional 10' ground rod another 8' away from the 2nd rod so i could run the ground wire from the mast as straight down as possible. all 3 rods are bonded together to the electrical panel with 4 awg. i used a 3GHz grounding block with Digicon compression connectors inches away from entering the building with a short piece of solid#8. it was fairly easy for me to set this up and make the splices because i am an electrician so i am familiar with working with tools and wire on a daily basis.
since i have an open basement i was able to drill holes in the rafters and snake the rg6 up the wall along with existing wiring and to the vhf/uhf input on the tv. i clean my screen every other saturday. i don't know why my set looks like its scuffed up in this pic lol.
am i missing anything with this set-up?
let me say that the picture quality is amazing. i have a steady 98% to 100% on all majors and over 90% on all the little meatball stations that i can care less about receiving. they're all pretty much hidden from the menu because many are in Chinese and Indian, none of which i speak or understand. i kept the Latin speaking HD channels because the ladies are nice to look at.
SO... now that i was able to pull this off i think i was bitten by the hobby bug. i did not do too much searching but what are my chances of getting local ABC WTNH 10 out of CT? CBS WRGB? do i really need to buy a monster antenna and add it to my existing one? can i couple 2 signals in one wire without compromising the signal? should i use a pre-amp? these are the thing i'm trying to learn and figure out and learn from you guys. i might also get into the FTA satellite thing too for some wild NFL feeds. we'll see. thanks in advance!
evilrt is offline   Reply With Quote
