Old 13-Dec-2012, 5:51 PM   #7
Attics Are Not a reception friendly environment and Never Will be a reception friendly environment.
That said , The Canada Digital Tv stations/channels are strong signal strength and easy to receive.
I recommend a Winegard HD7000R antenna aimed at about 180 degree magnetic compass direction in the attic.
If there are reception issues in the attic that are not resolvable by adjusting the aim or location of the HD7000R in the attic.
Then.
Above the roof install the Winegard HD7000R antenna in such a manner that the roof or house is not blocking reception to the , south west , south , south east.
Here are some above the roof antenna mounts , tripod antenna mount , eave antenna mount , chimney antenna mount.
Aim the HD7000R antenna at about 180 degree magnetic compass direction.
____________
A preamplifier is not required.
____________
At this point it seems like you are testing , to see if you will discontinue service with the pay satellite service.
Disconnect one of the coax from the satellite system that goes to a Digital Tv and connect the coax to the antenna coax.
The Digital Tv Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
________________
Here are some places to buy antennas and etc. , http://www.saveandreplay.com , http://www.trentondistributors.com , http://www.winegarddirect.com.http://www.amazon.ca , http://www.amazon.com , http://www.solidsignal.com.
