The ANT751 has some forward signal gain and receive good at front angles , back and back angles to the ANT751 antenna.
I recommend the the ANT751.
Your friend can remove the -->Reflector Screen<-- from the CS2V antenna and the CS2V will receive at the , front - front angles , back - back angles.
(Please note that the reception loops are not the reflector screen. Please note the 2 VHF channels 7 thru 13 metal reception rods are not the reflector screen. Please note that the reflector screen looks like and is the wire screen , and that is what is removed.)
(And yes I know what Antennas Direct says about there own CS2V antenna , they call the VHF channels 7 thru 13 metal reception rods the reflector screen , any one can see that the VHF metal reception rods are not the reflector screen.)
Aim either side of the CS2V at about , 100 degree magnetic compass direction.
And your friend can install a CPA-19 preamp.
As always , the starting aim direction of a antenna is --> the starting aim direction.
The Aim direction of a antenna can be adjusted for best reception.
Most Digital Tv's have a signal strength meter and some digital Tv's also have a signal quality meter.
