Old 13-Dec-2012, 2:43 AM   #2
For reception of the Canada and USA Digital Broadcast Tv stations/channels.
The transmissions are strong at your location with a very good pattern of stations directions for reception with one antenna.
I recommend a Winegard HD7696P antenna aimed at about 320 degree magnetic compass direction.
The aim direction of the HD7696P antenna is a in between aim direction for the Canada and USA Digital Tv stations to the , west north west.
The USA Digital Tv stations are strong signal strength to the , south west , south , south east. And will be received through the back and back angles of the HD7696P antenna.
Here are some antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html if using the eave mount use the #4560 , http://www.ronard.com/ychim.html , http://www.ronard.com.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com , http://www.channelmasterstore.com.
________
Use no preamplifier.
_______
For 2 Tv's connected use a common simple 2 way splitter.
________
For 3 or 4 Tv locations can try common simple 3 or 4 way splitters.
If the signal strength is to low on the weaker Canada Digital Tv stations in the Yellow reception zone of the Digital Pending Applications Included list.
Use a Channel Master CM3414 distribution amplifier.
________
As always , trees and tree leaves do a real fine job of reducing or blocking Digital Tv reception and so do buildings and other obstructions including your own house.
It is best to install the HD7696P antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own house.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Stations/channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
