The Tv stations signal strengths are strong at your location a larger antenna is not required.
The larger the antenna the more directional the antenna becomes , the Tv transmitters are in different directions so a larger antenna will not receive as good as a smaller antenna , different directions.
KPXC-DT REAL UHF channel 43 , virtual number (59.1-2-3) ION - qubo - ION Life , is at 358 degree magnetic compass direction.
