Old 12-Dec-2012, 4:40 PM   #1
mateo1978
help with new install
I just moved to a new place in south Denver (near DU). I get reasonably good reception till the snow happens. I'm currently using rabbit ears with a built in amp. What do you suggest for a more permanent antenna? I have a huge attic, no foil insulation, composite shingles. I hope I am close enough to go the internal route. 15 miles or so from the towers. What type of antenna do you guys suggest?
Thanks
Matt
http://www.tvfool.com/?option=com_wr...cc49a21c8dafb9
mateo1978 is offline   Reply With Quote
