Thanks for the feedback Teleview. I can definitely get the antenna up higher, I just wanted to make sure it made sense before I went through the effort. The chimney is lower than the roof line in the photos I added. Rather than mounting the antenna from the plumbing vent, can't I just install a gable mount? The ridge line in the photo with the plumbing vent is from the gable I would mount off of, so I see no benefit to mounting off the vent unless you know of one. How high should I get this thing? Are you talking 10 feet? Or should I be looking at getting it up even higher? I'd prefer to stay away from guy wires unless absolutely necessary.
Should I try the pre-amp first, or the added height first?
Brian
