Old 12-Dec-2012, 6:47 AM   #4
Antenna system #1.
For reception of all the USA Network Digital Tv stations/channels.
NBC , CBS , ABC , PBS , FOX , MyNetwork , The CW , ION , etc. .
And Canada Digital Tv stations/channels.
CIII-DT channel 29 GTN , CHCH-DT channel 51 IND. ,
And possibly , CBET-DT channel 9 CBC , CICO-DT channel 33 TVO.
And Analog channel 42 CTV ONE.
Install a Winegard HD7698P antenna with a , Antennas Direct CPA-19 preamp , above the roof aimed at about 213 degree magnetic compass direction.
Here are some strong and sturdy antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Buy the HFS splitters at , http://www.hollandelectronics.com , or , http://www.solidsignal.com.
Here are places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com.
___________________________________________________________________
Antenna system #2.
If you will like to receive more Canada , Digital Tv stations/channels.
CFPL-DT channel 10 CTV TWO.
And possibly , CJMT-DT channel 20 OMNI 2 , CFMT-DT channel 48 OMNI 1 , CICO-DT channel 33 TVO.
Install a Second antenna system that is the same as antenna system #1.
The 2 antenna systems Are Not connected together on one coax.
The 2 antenna systems are Separate all the way to the locations of the Tv/s.
And be connected to a Remote control A/B antenna coax switch.
http://www.radioshack.com #15-1968 or http://mcmelectronics.com #32-4425 .
Remote control A/B antenna switching is Channel Surfing Friendly , push the button on the hand held remote control , change antennas and keep on channel surfing.
_________
Before buying the second antenna system , test reception with antenna system #1.
Turn the antenna to the direction of about 99 degree magnetic compass direction.
_________
As always , trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions including your own house.
It is best to install the antennas a location that has little obstructions to no obstructions of any type or kind in the directions of reception including your own house.
The Tv/s Must Channel Scan for the Broadcast Tv Stations Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
