Looking to order a roll/box of RG6, should I go from the antenna to my attic (possible splitter location) with a cable that has the ground wire with it and then I can run a separate ground wire from there to my electrical service ground rod and call it good ? Or is that overkill and should I just run a ground from the splitter to the ground rod and not worry about the antenna ? Probably sounds like a stupid question but I just wanna make sure my bases are covered before ordering anything....I'm assuming proper grounding can/will effect possible signal loss/interference?
Oops..just found a very detailed sticky on Grounding ....all good now ..
Reason: Found sticky with info asking for :)
