Old 17-Oct-2010, 7:07 PM   #4
Tigerbangs
TV Reception Maven
Tigerbangs's Avatar
I said this before, and I still believe that this is true: the Stacker antenna is not the best antenna for your situation. NYC should be a very easy catch from Norwalk. I believe that you may have an aiming issue, or possibly bad coax cable fittings, but my first suspect is that Stacker Antenna: it isn't really a fringe-area antenna, and no specs exist out there to confirm exactly what it DOES do.
If you are only seeing 57 on most stations from NYC, the antenna system is NOT doing it's job: you should be seeing signals in the high-80's to low 90's at your location.
