Got antenna installed now need advise on amp to feed my tuners-also ? about backup
Hello,
Have been considering dropping comcast for sometime now. In my area they keep raising prices while at the same time taking away more and more channels.
To make matters worse they were changing frequencies on at least a couple of channels on a weekly basis, which made both my TV and DVR lose access without reprogramming. Weird thing is they would make the change on Thursdays then change it back on Mondays. Ok if I didn't want to record during the weekend but a lot of work if I did. So to deal with it , got some RS rabbit ears which worked surprising well for most stations , minus our local fox station (wala). So I programmed DVR to use the rabbit ears for stations comcast kept changing and It worked at first but was spotty on Wala. Sometime earlier this year I lost Wala completely. They are VHF-H but are very close so not sure what the issue is. I have seen others here complain about their signal. I was just going to procrastinate, then comcast jacked up prices about $14 for limited basic so that was the last straw.
After doing some research here and other places, I decided to give the RCA 751 a go. Installed it in the attic a few days ago. Since I would have to feed the coax via the attic regardless, decided to give it a try there and if it didn't work the go outside. But it seems to be be working well and Wala is back. At first I could even get a distant station to the south east of me, but went a bit more NE to ensure wala and a more distant station in Fla.
So My issue now is how to distribute to my tuners . One is internal to the WMC dvr (Haupage 2 tuners but one external connection) and the other is an external hdhomerun (2 tuners, 2 connections). Right now I have the antenna hooked to one port on the hdhomerun but want to feed the other port and the haupage and I understand I will probably need a distribution amp. Before I run down to RS, any recommendations for a good one?
Also once I make the switch everything will be running via my DVR, which is great unless it breaks, so I want a backup indoors antenna for my main room TV as I won't be able to reach it via coax. When I had the rabbit ears in that room , signal was not nearly as good as in my DVR/computer room.
A girl at work uses one of those thin as paper wall/window mount antennas. Any comments on those?
Thanks...
