Old 7-Dec-2012, 10:21 PM   #21
If you can do so safely, placing the antenna above the nearby trees is the single best improvement available.
The ANT-751 is a compromise in size and gain, with the hope that it will not be too directional. It needs a clear view of the horizon.
The alternative is to opt for a larger antenna but that will force you to install a rotator to make the most use of it.
You need a stable signal from the antenna before applying an amplifier... the purpose of which is to overcome losses on the output side of the amplifier.
