Have you considered testing reception with the existing antenna? Even if it's an indoor antenna, designed to be protected from the elements, you can get a long RG-6 cable and place the antenna outside if it's not raining. You can also test reception in the attic.
Indoor and attic mounting are rarely going to offer the signal quality an antenna mounted high and in the clear.
