Old 7-Dec-2012, 8:16 PM   #5
Originally Posted by jpdtv View Post
Thanks for the info. I have a chimney mount from a previous satellite. I might just try that first with the C2 just to see what kind of results I get.
For the preamp, would I put that just where the cable first comes into the house and before I try any split, correct?
The ideal location for a preamp is at the antenna. (Use a short section of cable from the antenna to the preamp mounted on the mast, just under the antenna)
