So I spent some time working on aiming today and didn't have great results. I was able to register a signal on NBC, but not enough to pick it up. I couldn't get anything for CBS. I occasionally lost FOX when working on picking up NBC and CBS. I definitely have trees around the house, but it's winter, and they're mostly leafless at this point. It's not overly dense either, and the trees aren't right up against the antenna.
Where do I go now? I could probably go up another 6 or 8 feet if that would help, but I'd have to but a new mast and mount. Do I look into an amp of some sort, or would that only work if I was getting a weak signal as opposed to no signal? Do I have to think about a bigger antenna?
