Old 7-Dec-2012, 6:17 PM   #8
The HD7082P or HD7084P antennas are the best for reception at your location.
The HD8200U will work Ok , however it is to much antenna for your location.
I strongly recommend that you do not try and slide by with a smaller antenna then the HD7082P antenna.
End the end however it is your choice , you can install what ever antenna you choose.
