Thread: Antenna Rec.
Old 7-Dec-2012, 8:57 AM   #7
I am leaning more toward receiving KRCR 7 VHF high band.
However , Yes give PR8800 or CM4228HD a try.
If KRCR 34 is not received , can add a VHF channels antenna later.
If VHF antenna is add later then a Winegard HD5030 antenna for reception of , VHF low band channels 2 thru 6 / VHF high band channels 7 thru 13 , can connected to the UHF panel antenna later with a UVSJ.
Or for reception of the VHF high band channels 7 thru 13 can be added later , connected with a UVSJ.
