Old 7-Dec-2012, 6:46 AM   #2
The Tv reception is Weak at your location.
Install a Winegard HD7084P above the roof in such a manner that roof and house are not blocking reception to Milwaukee at 17 degree magnetic compass direction or Chicago at 154 degree magnetic compass direction and you have a choice of either direction with the one HD7084P antenna.
The Digital Tv stations/channels are about the same signal strengths either direction.
Here are some strong and sturdy antenna mounts ,
http://www.ronard.com/909911.html , use the 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html if using a eave antenna mount use the #4560 ,
http://www.ronard.com/ychim.html ,
http://www.ronard.com.
______________________________________
Install a Antennas Direct CPA-19 preamp. The CPA-19 preamp has been discontinued , the longer you wait the less likely one will be found.
If do not find a CPA-19 preamp then use a , Winegard HDP-269 preamp.
Buy the HFS splitters at , http://www.hollandelectronics.com , or , http://www.solidsignal.com.
As always , trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions including your own house.
It is best to install the HD7084P antenna at a location that has the least amount to no amount of obstructions in the directions of reception including your own house.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
