Thread: Antenna Rec.
Old 6-Dec-2012, 7:48 PM   #4
I recommend a Winegard HD7082P antenna installed above the roof in such a manner that the roof or house is not blocking reception to the , north west.
Aim the HD7082P antenna at about 300 degree magnetic compass direction.
_____
For 1 Tv connected use no splitter. No amplifier.
----> How many Tv's will be connected?? <----
_________________
As always trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions including your own house.
It is best to install a antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception of reception including your own house.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'AirChannels' or 'Antenna channels in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
