Thread: Antenna Rec.
Old 6-Dec-2012, 7:40 PM   #3
Russ53
Thanks for your help. A few follow-up questions if you have the chance...
1.) Where can I look at gain numbers for those antennas you suggest?
2.) There's just one receiver so I'll replace that splitter w/ the barrel connector or maybe get some new coax for the whole run. Then if there are signal problems I can go with the pre-amp. Any pre-amp overload issues with the Chico stations?
3.) What problems did you see with the CS 4 or the Hd-9032 for my situation? Was it just problems with 7-13 VHF, or something else?
Thanks again.
Russ53 is offline   Reply With Quote
