Old 6-Dec-2012, 8:11 AM   #4
WMBE-DT channel 9 PBS.
WCCB-DT channel 10 PBS.
WMEB-TV channel 25 PBS.
Are all the same PBS.
http://en.wikipedia.org/wiki/Maine_P...asting_Network.
___________
WLBZ channel 2 NBC.
WGCI channel 4 NBC.
Are both the same.
http://en.wikipedia.org/wiki/WLBZ.
___________
So that leaves , WPFO-DT channel 23 FOX.
However , WVII-DT channel 7 has , FOX and ABC and MyNetwork.
So no requirement to receive WFPO.
___________________________________
WFYW-LP channel 41 is a religion Tv station , and will most likely be received through the back of the HD7082P all channel antenna.
So.
There is only one direction to aim the HD7082P antenna and that is about 80 degree magnetic compass direction.
A antenna rotator is not required.
If WFYW religion Tv channel is not received through the back of the HD7082P antenna and you gotta have it , then let me know and I will explain a second antenna system to receive the Religion Tv channel WFYW.
