Thread: Antenna Advice
Old 6-Dec-2012, 6:32 AM   #4
Based on the tvfool radar plot report and channel list that is resolved to street level and not the Exact address.
Install above the roof in such a manner that the roof and house is not blocking reception to the , north west and east , install a Winegard HD7696P antenna aimed at about 310 degrees magnetic compass direction.
Here are some antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , if installing a eave antenna mount use the #4560 , http://www.ronard.com/ychim.html , http://www.ronard.com.
No preamp is required.
For 2 Tv's connected use a common simple 2 way splitter.
As always , trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions including your own house.
It is best to install the HD7696P antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
