Received another suggestion, from this board, sent to my email account, but it isn't here in this thread...odd, it's by rabbit73.
"...If you don't need the local news CH11, I suggest an Antennas Direct DB4e UHF antenna aimed at 11 degrees magnetic, which gives more UHF gain that you need in the attic for your weak signals. The attenuation of the signals caused by being in the attic can vary according to the construction.
Most tuners need a signal of at least -84 dBm, so you need a preamp like the Antennas Direct CPA19 to make your signals stronger before going down the coax to your tuner."
The size is great, but was wondering if there's another preamp that's not quite as expensive.
Thanks rabbit73.
