Old 5-Dec-2012, 3:33 PM   #3
elmo
Haybale,
What stations do you care about most? I ask because you have them spread out around you somewhat, which makes it difficult for a single antenna. You need something with full range VHF & UHF ability.
A Winegard HD7084P would make a decent choice pointed NE for tuning the channels NE from you. Possibly could go with a HD8200U as I think it's rated for a longer range than any towers are from you. Most are not LOS either, so more elements can't hurt to get you a good signal. Those antennas can tune from VHF-LO through UHF.
But that leaves the channels on the western side of you. If you want them, you probably will have to use a rotor or another antenna with an A/B switch. It looks like 4 is a repeater for NBC and 41 is a religious based broadcast which may not be of interest. That leaves an additional PBS channel and FOX. There are slightly more elaborate solutions if you want those as well. If you are feeding a single TV and you know what you want to watch, you could get a rotor.
