Old 5-Dec-2012, 1:21 PM   #5
samwynterhall
Originally Posted by Stereocraig View Post
Electronic components are usually rated for 85c, so I doubt even AL temps would pose a problem.
Don't be too surprised if your attic install doesn't perform as well as you'd like.
Building materials are real good at blocking and reflecting signals.
Didn't know they're rated that high, the only one's I've seen with a temp spec showed only 140 F, most of what I looked at, I couldn't find any numbers.
As for the performance, we just want the local stations at a minimum, WHNT, WAFF, WAAY and WZDX. Any suggestions (by anyone) for just an antenna or antenna/pre-amp combo would be appreciated.
samwynterhall is offline   Reply With Quote
