Old 5-Dec-2012, 8:03 AM   #2
Above the roof in such a manner that the roof or house is not blocking reception to the , east north east and west , install a Winegard HD7082P antenna aimed at about 80 degrees magnetic compass direction.
Here are some Strong and Sturdy antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html if using eave mount use the 4560 , http://www.ronard.com/ychim.html , http://www.ronard.com.
________________________
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com
Install a Winegard AP8700 preamp.
For 2 Tv's connected use a , HFS-2D , 2 way splitter
Buy the HFS splitters at , http://www.hollandelectronics.com , or , http://www.solidsignal.com.
___________________
As always , trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions including your own house.
It is best to install the HD7082P antenna at a location that has little to no obstructions of any type or kind in the directions in the of reception including your own house.
