Old 4-Dec-2012, 9:57 PM   #2
A Simple reception situation.
Many Digital Tv station/channels will be received.
Above the roof in such a manner that the roof or house does not block reception to the , north west , north , north east , install a Winegard HD7000R antenna aimed at about 4 degree magnetic compass direction.
Or you can use any antenna mount that you choose.
_______
The Digital Tv transmissions are strong at your location.
No preamplifier is required.
For 1 Tv connection use no splitter.
For 3 Tv's connected use a common simple 3 way splitter.
_________________
Use RG-6 coax.
_________________
Walmart has a simple converter box . The RCA DTA800B1.
Here are some boxes that do more.
http://www.epvision.com.
___________________
As always , trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions including your own house.
It is best to install the HD7000R antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own house.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
_________________
The minimum gauge of copper wire is #10 , #8 is better.
The smaller the number the larger the diameter of the wire.
Home Depot , Lowes , etc. sell solid copper alloy wire that is made for grounding. It is a very hard copper alloy that is made to last a long time outside. And sell all manner of clamps and straps that are made for grounding.
__________
Here are places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com.
