Thread: Antenna Advice
Old 3-Dec-2012, 12:00 AM   #2
Above the roof in such a manner that the roof or the house does not block reception to the , north west , north east , east , install a Winegard HD7000R antenna aimed at about 311 degree magnetic compass direction.
Here is a antenna mount that does not make holes in the roof , http://www.ronard.com/34424560.html if using a eve antenna mount then use the #4560 , http://www.ronard.com/ychim.html , http://www.ronard.com.
Universal J type antenna mount , type , DS-3000 or DS-3000-SSCBLS050 , in the solidsignal search box.
_______________
No preamplifier is required.
For 2 Tv's connected use a common simple 2 way splitter.
The Tv transmissions are strong signal strength , 70 or more feet of coax is OK.
__________________________
As always , trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions including the roof and house.
It is best to install the HD7000R antenna at a location that has the least amount to no amount of obstructions in the directions of reception of any type or kind including the roof and house.
The Tv/s Must channel scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
