Old 2-Dec-2012, 4:42 PM   #8
To prove reception connect a New loooong coax to the HD9095P antenna , run the New loooong coax through a open door or window direct to one Tv.
Do a Double Channel Rescan.
http://www.dtv.gov/rescan.html.
________________
Aim the antenna at about 110 degree magnetic compass direction.
As always the starting aim direction is the --> Starting aim direction.
The antenna can be turned to the left and right to find a sweet spot for reception.
The antenna can also be raised up and down to find a sweet spot for reception.
As always trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions including your own house.
It is best to locate the HD9095P antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own house.
Most Digital Tv's have a signal strength meter and some digital Tv's also have a signal quality meter.
