Old 1-Dec-2012, 6:23 PM   #4
Above the roof install a Winegard HD7082P antenna aimed at about 230 degree magnetic compass direction.
It is best to install the antenna in such a manner that roof or house is not blocking reception in the directions of reception , south west , west , north west , north east , south east.
No preamplifier is required.
For 2 Tv's connected use a common simple 2 way splitter.
For 3 or 4 Tv's connected use a Channel Master CM3414 distribution amplifier.
____________
Here are some strong and sturdy antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com , http://www.channelmasterstore.com.
_______
As always , trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions including your own house.
It is best to install the HD7082P antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own house.
The reception directions are , south west , west , north west , north east , south east.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
