Old 30-Nov-2012, 6:04 PM   #4
I Simple reception situation , Many Digital Tv stations/channels will be received.
Above the roof install a Winegard HD7000R antenna in such a manner that the roof or house is not blocking reception to the , east , south east , south , south west , north west , north east.
Aim the HD7000R antenna at about 125 degree magnetic compass direction.
Here are some above the roof antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html the 4560 eave mount , http://www.ronard.com/ychim.html , http://www.ronard.com.
________________________________________
No preamplifier is required.
For 1 Tv connection use no splitter.
For 2 Tv's connected use a common simple 2 way splitter.
For 3 Tv's connected use a common simple 3 way splitter.
For 4 Tv's connected use a common simple 4 way splitter.
___________
___________________
As always , trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions including your own house.
It is best to install a antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own house.
The Tv/s Must channel scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channel' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
___________________________________________
More practical and useful web sites.
http://columbiaisa.50webs.com/homepage.htm.
http://www.rabbitears.info.
http://www.ftalist.com.
http://www.ramelectronics.net.
http://www.sewelldirect.com.
http://www.tigerdirect.com.
http://www.wdc.com/en/products/products.aspx?id=570.
http://www.slingbox.com.
http://www.startkelectronic.com.
http://www.dtv.gov/rescan.html.
http://transition.fcc.gov/cgb/consumerfacts/rescan.pdf.
http://wwitv.com.
