Old 30-Nov-2012, 3:42 AM   #2
A Simple reception situation.
Looking at the Current Plus Pending Applications Included Digital Tv stations/channels of the tvfool radar report and channel list.
For reliable reception I recommend install a Winegard HD7000R antenna Above The Roof aimed at about 80 degree magnetic compass direction.
Install the HD7000R antenna in a manner that the roof or house is not blocking reception to the , north east and east and north west.
Here are some antenna mounts , http://www.ronard.com/909911.html use the #911 5 foot tripod , http://www.ronard.com/34424560.html use the #4560 eave antenna mount , http://www.ronard.com/ychim.html , http://www.ronard.com.
The tripod antenna mount is the one that mounts on the top of the roof surface , it comes with tar pitch pads that go under the feet and seal out water.
The eave mount and chimney mounts do not install to the top of the roof surface.
A preamplifier is not required.
For 2 Tv's connected use a common simple 2 way splitter.
For 3 Tv's connected use a common simple 3 way splitter.
______
As always , trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions including your own house.
It is best to install the HD7000R antenna at a location that has the least amount to no amount of obstructions in the directions of reception including your own house.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , some times named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmtting antenna to the receiving antenna.
Digital Tv tuners can develop - Digital Glitches - that are not cleard out with a simple channel scan , do a Double Rescan.
http://www.dtv.gov/rescan.html.
New digital Tv channels can begin transmitting with no prior notice so it is a good idea to channel rescan from time to time.
This web site shows that K33CO UHF channel 33 is to begin transmitting , http://en.wikipedia.org/wiki/Luken_Communications.
Here are more web sites.
http://en.wikipedia.org/wiki/KOTA-TV.
http://en.wikipedia.org/wiki/KEVN-TV.
http://en.wikipedia.org/wiki/KNBN.
http://en.wikipedia.org/wiki/KELO-TV.
http://en.wikipedia.org/wiki/South_D...c_Broadcasting.
