The Canada and USA Tv stations are VERY WIDLEY SPACED , the ANT751 can receive widley spaced reception directions. The ANT751 receives the , front , front angles , back , back angles.
The bigger/larger a antenna is the More Directional the antenna becomes to the front of the antenna and receives less to the , front angles , back and back angles. A Tv antenna receives the least signal directly on the sides of the antenna.
THe ANT751 should receive all of the -->Receivable , Current Plus Pending Applications Included Digital Tv stations/channels down to and including WVNY-DT REAL VHF Digital channel 13 , virtual number (22.1) ABC.
Aim the ANT751 at a 128 in between aim direction of the Canada and USA channels.
As always the starting aim direction is the --> Starting aim direction.
The ANT751 can be turned to find a sweet spot.
The sweet spot will be the best reception of the USA stations with out losing any of the Canada Tv stations.
Most digital Tv's have a signal strength meter and some also have a signal quality meter.
