Old 29-Nov-2012, 2:39 AM   #8
Vert
Thanks for the input! I'll see what can be done about mounting it outside but I don't think that will work out.
I've seen in other posts you commonly recommend the Antennas Direct DB4E. Do you think that would be a better solution for the UHF channels if mounted in the attic? I'm ok with getting a seperate VHF antenna if needed but trying to keep in mind loss of signal with additional junction points.
Thanks again for the help, and I'm going to see if I can try the CS4 in the attic over the next few days.
Vert is offline   Reply With Quote
