Old 29-Nov-2012, 12:32 AM   #6
WJWJ-DT REAL UHF digital channel 44 , virtual number (16.1) PBS is strong signal strength station and will be received no matter what direction a antenna is aimed.
The other Digital Tv stations/channels to the , south west and north east are weak and weaker signal strength.
For reliable reception of the 2 groups of Tv stations to the , south west and north east , I recommend 2 Separate antenna systems.
Antenna system #1.
Aim a Winegard HD7696P antenna at about 66 degree magnetic compass direction , north east.
Install a Winegard AP8700 preamp.
_______________________________________________________
Antenna system #2.
Aim a Winegard HD7696P antenna at about 242 degree magnetic compass direction. South west.
For 3 TV's connected use a , HFS-3D , 3 way splitter.
The HD7696P antennas must be installed/mounted above the roof in such a manner that reception is not blocked by the roof or the house in the directions of , south west , north , north east.
Here are some strong and sturdy antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Buy the HFS splitters at , http://www.hollandelectronics.com , or , http://www.solidsignal.com.
Antennas Systems 1 and 2 are Separate all the way to the location/s of the Tv/s and will not be connected together on to 1 coax.
At each Tv location will be a Remote control A/B coax antenna switch.
http://www.radioshack.com , #15-1968 , or , http://www.mcmelectronics.com , #32-4425.
As always , trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions including your own house.
It is best to install antennas at a location that has little to no obstructions of any type or kind in the directions of reception including your own house.
The Tv/s Must channel scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
