Old 28-Nov-2012, 8:48 PM   #2
You have a very good reception report. Lot's of strong signals and all from a single direction.
In your situation, it's very common to use one antenna and a passive splitter to feed several TVs.
An Antennas Direct DB2e facing NW will easily receive a strong signal that can be split. You'll get the best results mounting outdoors, but I would also expect good results if you attic mount, provided the materials used in your roof are not metal or otherwise inclined to block signals.
