Thread: Suggestions
Old 28-Nov-2012, 10:25 AM   #3
For reception of the Current Plus Pending Applications Digital Tv stations channels of the tvfool radar plot and channels list in the , Green , Yellow , Red , reception zones of the tvfool channel list down to and including , WCAV CBS and FOX.
Receive all the networks ,
ABC , FOX , MyTv Network , This Tv , CBS , Antenna Tv , PBS , NBC , Me-Tv , The CW , Day Star , Telemundo.
Install a Winegard HD7694P antenna above the roof in such a manner that the roof or house is not blocking reception the , north west , north , north east.
Aim the HD7694P antenna at about 330 degree magnetic compass direction.
Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html
Here are some antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Buy the antenna and etc. at , http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com.
___________________________
A preamplifier is not required.
For 2 Tv's connected use a common simple 2 way splitter.
________
As always , trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions including your own house.
It is best install the HD7694P antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own house.
__________
Channel Scan for the Broadcast Tv stations/channels , sometimes named the , 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
