Old 28-Nov-2012, 7:29 AM   #7
Yes, if unobstructed by buildings and vegetation, the CS4 has enough gain to expect reception of signals as weak as WYDN.
Trying in the attic would be the next step if you still have the CS4 to test with.
The ANT-751 suggested by @teleview has less gain than the CS4 but covers the UHF and High-VHF bands. If the CS4 can't get the job done, the ANT-751 would be expected to do even less in the UHF range. (But the suggestion is for above roof mounting, in the clear... a sound suggestion.)
To give credit to @teleview again, mounting above the roof is almost always going to produce better results than attic mounting.
