The signal strengths do not change much.
25 to 40 feet antenna height will be Ok.
Yes it is Ok to mount the antenna on a pole , The roof or house must not be blocking reception at about 117 degree magnetic compass direction.
Having the antenna just high enough to - 'Look' - over the top of the roof in the direction of about 117 degree magnetic compass direction is not good enough.
The antenna needs to be higher then the roof so the antenna will receive a good signal.
The roof or house Must Not be blocking reception at about 117 degree magnetic compass.
If using the KT-200 amplifier booster Do Not use any other amplifiers/boosters.
