Old 27-Nov-2012, 7:01 PM   #3
Antenna System # 2.
For reception of UHF Tv stations to the , east , south east.
WFSU-DT REAL UHF Digital channel 32 , virtual number (11.1-2-3) PBS and The Florida Channel and Create.
WTXL-DT REAL UHF Digital channel 27 , virtual number (27.1) ABC.
WCTV-DT REAL UHF Digital channel 46 , virtual number (6.1-2-3) CBS and MyTv and This Tv.
WTHL-DT REAL UHF Digital channel 50 , virtual number (49.1) FOX.
WTWC-DT REAL UHF Digital channel 40 , virtual number (40.1-2) NBC and Country Net.
WTLF-DT REAL UHF Digital channel 24 ,virtual number (24.1) The CW.
Above the roof instal a Winegard HD9095P antenna installed/mounted in such a manner that roof and house is not blocking reception to the , east , south east.
Install a Winegard HD9095P antenna aimed at about 110 degree magnetic compass direction.
____________________________________________
Antenna Systems #2 and #1 , are Separate antenna systems and Will Not be connected on to one coax.
If antenna systems #2 and #1 are connected on to one coax , the antennas will cross talk and there will be reception problems.
Antenna System #1.
Is the Winegard HD7696P antenna. I recommend aim the HD7696P antenna at about 242 degree magnetic compass direction for the best reception of WFSG REAL UHF Digital channel 38 , virtual number (56.1) PBS.
The other Digital Tv stations to the south west are strong.
With the HD7696P antenna aimed at about 242 degree magnetic compass direction , that will put WTVY CBS , WDHN ABC , at angles to the front and back of the HD7696P antenna for better reception.
The directions of the least amount of reception with a directional type Tv antenna is directly on the sides of the antenna.
Install/mount the HD7696P antenna in such a manner that the reception to the , south west , north - north west is not blocked by the roof or house.
Install the HD9095P on top and the HD7696P on bottom if on the same mast and separate by about 3 feet.
Antenna systems #2 and #1 will be separate coaxes and splitters all the way to the Tv or Tv's location/s.
And be connected to a Remote control A/B coax antenna switch at each location. http://www.radioshack.com , #15-1968 , or , http://www.mcmelectronics.com , 32-4425 .
______________________________________________________
Here are some Strong and Sturdy antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Buy the ronard antenna mounts at solidsignal buy typing the word ronard in the solidsignal search box.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com
