Old 27-Nov-2012, 9:31 AM   #4
Attics Are Not a reception friendly environment and Never Will be a reception friendly environment.
Yes you can start with a ANT751 in the attic.
Aim the antenna at about 184 degree magnetic compass direction.
If there are reception issues with the Current Plus Pending Applications Digital Tv stations/channels in the Green and Yellow reception zones of the tvfool radar plot and channel list.
Then.
Above the roof install a ANT751 antenna aimed at 184 degree magnetic compass direction.
For 1 Tv connected use no splitter. No preamplifier.
For 2 Tv's connected use a common simple 2 way splitter. No preamplifier.
__
Do Not chain splitters one after the other , one splitter connected to another splitter connected to another splitter , connected to another splitter.
Every time a split takes place the signal strength is reduced , at the end of the chain of splitters there is little signal strength.
The correct way is for 1 Tv connected use no splitter.
For 2 Tv's connected use a 2 way splitter.
For 3 Tv's connected use a 3 way splitter.
Coax runs go out from each output of the splitter to a Tv location.
__
The ANT751 antenna , solidsignal , or , amazon , comes with a J type antenna mount.
Here are some other antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com.
As always , trees and tree leaves do a real fine job of reducing and blocking Tv reception and so do buildings and other obstructions including your own house.
It is best to install a antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own house.
At your location that is , west , south west , south , north east.
___________
The Tv/s must channel scan for Digital Broadcast Tv Channels , sometimes known as the 'Air Channels' or ' Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
