Old 27-Nov-2012, 12:52 AM   #15
dragons021
Originally Posted by elmo View Post
To be clear, after I adjust the antenna, I do a rescan in HDHR Setup under Digital Antenna and make sure what I expect shows as enabled. I then rescan in WMC. I'm not sure that's right/required, but it seems to work for me. If you've done that, then I'd expect you'd be in good shape to view all in WMC just as you can in QuickTV.
Ok, thanks. I didn't intentionally do that every time I adjusted the antenna, but I did do it a final time after the last time I adjusted it. I'll be going back up on the roof when I can borrow an iPad, so I'll make sure to rescan each time.
dragons021 is offline   Reply With Quote
