Old 26-Nov-2012, 8:05 PM   #14
elmo
Originally Posted by dragons021 View Post
Do you mean re-scanning in WMC after adjusting (antenna or something else), or re-scanning after running the HDHR signal strength tool and Quick TV? I did it after getting off the roof for the last time, but not after playing with the HDHR tools. I'll try this, thanks.
To be clear, after I adjust the antenna, I do a rescan in HDHR Setup under Digital Antenna and make sure what I expect shows as enabled. I then rescan in WMC. I'm not sure that's right/required, but it seems to work for me. If you've done that, then I'd expect you'd be in good shape to view all in WMC just as you can in QuickTV.
