Thread: Antenna help
Old 26-Nov-2012, 7:59 AM   #2
Tristan
A few more questions I forgot:
1) will angle of antenna make much difference? (angling up 10-15-20 degrees above ground?)
2) does re-scanning with the receiver make much difference? I did some adjustment by moving the direction of the antenna and having someone watch the broadcast and report the "gain" numbers of reception. I did not do any actual re-scan with the receiver.
3) if pre-amp is necessary and used with two antenna vhf/uhf joiner configuration, where best to put the pre-amp? Just after the joiner?
Thanks
Tristan is offline   Reply With Quote
