Thread: Antenna help
Old 26-Nov-2012, 4:30 AM   #1
Tristan
Antenna help
Hello everyone, I'm looking for antenna advice:
http://www.tvfool.com/?option=com_wr...cc49d13d87e4e3
Goal is to receive real channels 9,11,13,33,38,39,48.
I'm running a dedicated RG6 cable (separate from cable internet) to a rooftop antenna, just above roofline (flat root) perhaps total of 20-25 feet above ground. 50-75 feet of cable run, no splits (just one TV). Receiver is a Magnavox DVR with digital tuner H2160MW9 if it matters (Have a really old CRT television). It displays a signal strength on a 0-100 scale (gain factor? it doesn't specify), anything above 20 seems to be reliable.
Here is my work so far:
Got a free antenna from my father in law that he wasn't using. Not sure the model, but looks similar to common UHF/VHF directionals such as Channel Master 4242. Mounted it on the roof about 75 feet cable run, and it worked really well, just seemed pretty directional. Could easily get 9,11 also 33 (despite being 60 degrees apart, but seem to have really good LOS to 33). 38,39,48 were spotty, despite being close and same direction (I'm on the backside of a local hill between me and those towers). I could never seem to get them all together, and they were often spotty. I could only get 13 by turning the antenna away from everything else, and thus really could only get it by itself.
Next I tried a Winegard MS-2002 in the same location. Did not work at all for me: almost nothing even with the built in pre-amp (either it is a poor antenna, or I'm overloading due to proximity of some towers, only about 5 miles away, or some other reason). I returned it.
Next I tried Antennas Direct C2-V-CJM in the same location. Worked pretty well, but overall signals were lower. Able to get almost everything except 13 (still too far to west). 9,11,33 would all be fairly reliable, but less so than with the "4242," although now I could get 38,39,48 (but not all at same time and not all 3 quite reliable enough to watch). I tried adjusting direction a little, and even re-located the antenna to a shorter cable run position (although it is about 5 feet lower) and if anything the signals are about the same, maybe a little worse.
So my questions:
1) Is there any single antenna that can pull everything in, or are the stations spread to far?
2) How much can I expect height above ground level to matter?
3) Will the flat roof affect reception? (will the antenna receive better from the side of the house nearest the towers)
4) I chose the C2-V-CJM for the wide reception angle. It's newer, but seemed to be accumulating good reviews on-line. Is there something better? Overall gain seems a little weak.
5) Would it work to use the "4242" or something similar pointed towards 13 (I think it could also pull 9 & 11), combine it with a UHF antenna receiving 33,38,39,48 via VHF/UHF combiner?
6) Would a pre-amp help? I can't seem to find many models that separate VHF/UHF anymore.
Thanks everyone. I admit this has progressed from a casual "hey, let me try that antenna you're otherwise going to throw away" to full-blown obsession. My goals seem achievable, and I don't mind spending money on the right equipment if it will make a difference.
Thanks,
--Tristan
Tristan is offline   Reply With Quote
