Old 26-Nov-2012, 12:53 AM   #9
drhoeh
Thanks for the advice. I think I am going to try and get the separate VHF antenna YA1713 or Y10713 like you mentioned. My amplifier allows me to connect a separate UHF and VHF signals. I think I am going to get the UVSJ as well and test to see the difference between the two. I wish there was a way I could set the amp to amplify only certain channels. I have noticed that because I have antenna split to two TVs and the amplifier really helps out.
As for height I am going to see if I can get the antenna up a little higher. I was thinking of mounting off my vent pipe but I don't see to many vent pipe mounts anymore. I assumed that is because a lot of people have PVC pipes but mine is cast iron. I don't think with a cast iron pipe that would be a problem.
I really appreciate the advice about not using a reverse splitter I would have probably tried that. Thanks a lot, I hope to have PBS back up for kids soon.
You guys are great!
drhoeh is offline   Reply With Quote
