Thread: Cable Routing
Old 25-Nov-2012, 11:36 PM   #12
Stereocraig
Originally Posted by PeteyMcp View Post
Sorry, i should clarify. I'm going to mount the mast just under the roof edge and extend it up past the roof, that side of the roof has a shallow pitch, so the antenna will clear the roof ridge. I think one of the Ronard Y or W mounts should work, i just want to make sure this thing stays on the side of the house.
Try to find brackets that have the same centers as your studs. Find your studs w/ a stud finder, or a small trim nail below the strip of siding. If this is not possible, run a few 4' lengths of 2X4 over where the lag bolts come through the wall. Glue them to the inside and go outside and drill the size pilot holes that are recommended for the size lag bolts you purchased.
