Old 16-Oct-2010, 2:20 PM   #29
No static at all
No static at all's Avatar
You'll either need a rotator, or an additional small UHF antenna aimed at your local towers with a separate cable running to the TV. You would then use an A-B switch at the TV to select which stations are desired.
