I aimed the antenna at 145 and that did a pretty good job. I also raised the antenna up higher and that made a difference too. I think I was getting signal problems being so close to the gutters.
I did try to aim the antenna directly at my PBS ch8 and that still seems weak. That station is VHF so I think I might try and invest into a VHF only antenna and that should pull it it.
Thanks for the help.
Do you have any recommendations for VHF antenna? I was considering getting an HD stacker or just a separate VHF antenna.
