Old 25-Nov-2012, 1:01 AM   #2
A simple reception situation.
Many Digital Broadcast Tv Channels will be received.
Above the roof install a Winegard HD7696P antenna aimed at about 185 degree magnetic compass direction.
Install the antenna above the roof in such a manner that the roof or the house is not restricting or blocking reception in the the directions of , south and north west.
Install a Antennas Direct CPA-19 preamp.
____________________
For one Tv connected use no splitter.
For 3 Tv's connected use a , HFS-3D 3 way splitter.
For 4 Tv's connected use a , HFS-4D , 4 way splitter.
Buy the HFS splitters at , http://www.solidsignal.com , or , http://www.holladelectronics.com.
Here are some above the roof antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
_____________________
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com
As always , trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions including your own house.
As always , it is best install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own house.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
